HELP!!Oil Spewing Out Rear End of Left Head
ward cleaver
Californication
I pulled into my kids music lesson yesterday to find oil flowing out from under my trucks engine near the oil filter,or so I thought. When I inspected it using a mirror at home it's coming from a 2" plug with a square hole in it on the firewall end of my left head. Anybody know what this plug is? and how I can fix it?
Those (should) be the High Pressure Oil end rail plugs.I've had a slight seepage from the drivers side plug on our 7.3L and from what I was told at Ford there is an updated plug with a better O-ring that seal much better.
You could try and put the 1/2" drive on it to see if it'll tighten down some,it's a tough to work area but was able to get about a 1/8-1/4 turn on em which helped.
tubzz
st.clair mo.
yep you have a o-ring leaking.you can try to tighten it up but you will need to get a new one.it is tight on the back of the head against the fire wall.good luck
JOAT
I Found Nemo!
The West Coast
High Pressure Oil rail end plugs Large plugs at each end of heads; incl. o-rings
(International) 1827535C94 (new style, blue o-ring)
I don't have the part number from Ford. If you get it there please post the PN and I'll pop it in the parts list.
rickh
Biodiesel Rules!
Bellevue Nerbaska
Oil rail end plug.
I was a ble to find direct replacement orings. They require a backup washer along with oring. The orings have been upgraded but you have to buy an entire plug to get the orings, I could not find them seperate at Ford or IH. Found the repalcement orings at an oring shop.
There is no tigtening to it. Once the plug/oring seats thats it.
Rick H...
ward cleaver
Californication
Thanks guys, this had me more than a little worried.
Hi ho, Hi ho, it's off to ford I go...
On second thought, which do ya think is better, Ford or IH?
ward cleaver
Californication
When I gave this part# (Ford # 4C3Z-6026-CA ) to the counter guy at ford it belonged to the plug on the HPOP reservoir. I had to show him on the picture of the head on his computer screen. (another # I didn't get). when he looked that part # up the computer gave us the above number as a replacement for the old part.
Sooo, the receipt says I bought part#4C3Z-6026-CA!
ANYHOW, I got the new improved blue o-rings, (got 2) and I had to buy the plugs too. $7.39 ea. (plug+O-ring). :santa2 __________________
