Question High Idle Question
blowinsmoke
charleston ,il
my guess is yes, the semi's where i work that have wet kits is done manually, but obviously this is electronic, tony wildman asked if mine was automatic for the shift points and what shape the trans was in. to decide how much power he could put to, it without tearing it up:eek:.
02 stroker I take it you are looking at doing the high idle mod by tapping into the fuel pedal assembly? if so then yes it is the same
02stroker
Gratz, Pennsylvania
I seen a post where it said to connect the wire that Ford uses to idle up the engine in PTO applications. Here is the link I found.
High Idle Mod
Sounds easy enough and I'm pretty sure the wires are there. I remember seeing some last time I was under the dash. I know there are some under the hood.
