High idle
Coleman
Houston BC
New to this forum I'm sure this has been discussed, but, I was told by my local dealer that my 2014 cannot use a idle control because even at a higher idle it will clog the exhaust filter. It would be nice to have high idle to warm the truck up come winter. I have seen a couple aftermarket ones that would have to be spliced into the harness which I'm not that comfortable with. What do you guys think ? Or is there a plug and play programmer available.
Thanks for any help.
Tbar
SDD STAFF/Moderator
I wired my 2004 F-350 myself, but that won't help you Tbar. Hope the switch shows up soon.
Dave :dunno
Coleman
Houston BC
I've installed the switch and works great. Only problem is that it won't work when you use the remote start, the key needs to be on to go into high idle.
I tried installing this switch today and couldn't get it to work. Double checked my wiring. Called BD for technical assistance but all they could offer was to replace the switch. Anyone else have trouble with the install?
No trouble with mine (Sagbel DYI) T but.. FWIW ? There's a 3-5 second delay from when you flip the switch and the RPM's actually coming up.
Trans in P, E-brake on.. flip the switch.. wait a second or 5 ? Try That ?
I'm think'n it's ECM/PCM logic/safety needs ??
On edit: >>WOW<< 5000 posts on SDD !!!!!!!
dserge66
