HOW DO YOU REMOVE THE HUBCAPS ON THE DUALLY'S
XTrmXJ
NACHHOOOOOOO!!!!
Hampton Va
How do you remove them, Im wanting to change the front brakes right now but cant seem to figure it out.. I know how the rears are removed but not the front..
They pop off like the rears. Use a screwdriver to pry them off. I have done this on a friend's 2000 PSD 4X4.
3-StarJ.R.
53 year old kid.....
Athens Tennessee ....
The front simulators are held on identical to the rears, for some reason the tabs seem to bite in alittle more on the front runners than the rears. A wide bladed pry bar and working it out a little at a time all around the outer flange will get it for you, good luck with it....
XTrmXJ
NACHHOOOOOOO!!!!
Hampton Va
I finnally got them, I just got done with the brake change.. The front was a bitch becuse they wouldnt give becuase of the inner holding ring was rusted.. The back I found you have to find 2 different nut caps that are different and pull those off to get the cap off
