HPOP Removal - Can't Get Hoses Off
bbressler
Happy, TX
As the title states, I trying to pull my HPOP to trace down an oil leak. The front HPO hose fitting is loose, but I can't get the hose part off of the fitting that goes into the pump. Is there any trick to it? I don't want to force it too much and break the pump or the hose. I got the back one off without much trouble, but this front one is killing me.
bbressler
Happy, TX
Disregard....as usually happens, I try again right after I post and it works....was just stuck really good. Added some more elbow grease, got it off. Found a worn o-ring on that connection, hopefully that was my problem...
