I have a dumb question
J_F250
SDD Burger Flipper
Monteagle, TN
Where is the block heater hook up? I am beginning to think my Lariat does not have one. I went out to start my truck this morning and it was 8 degrees F and took me 3 times to get it to crank up....then it sounded like it was going to blow up :dunno
Tbar
SDD STAFF/Moderator
Tucked and tied behind the front license plate...........
Tbar
93turbo_animal
Marengo,ohio
if that don't help find your oil filter then just above it is the block heater follow the wire and there you go
platinum01
Willis, TX
It will help alot on the starting. Even though it doesn't get that cold here if it gets into the 30's I plug the truck in and first crank the truck starts.
J_F250
SDD Burger Flipper
Monteagle, TN
OK It looks like the receptacle is missing. I have two wires coming out of some loom at the front with no end on it. I have two wires there that are red with a blue stripe and I think a blue.
Can anyone confirm the wire colors?
If that is the case....Is it cheaper/worth fixing it or get a new one?
trackspeeder
Stone Crusher
North Branford CT
That aint it.:D
With no end. It would look like a black flat three wire cord. Center is ground.
Toptech
West Virginia
Mine was to the left (toward the center of truck) of the driver side tow hook, tie strapped to my fog light harness. Hope this helps.
silverF250
Arnold, Mo
If it is missing the plug I would suggest getting a new cord. I have seen the front end of a truck that the cord caught fire and it ain't pretty.
dserge66
