id plate
scoutman77
iowa
where can a person find out what the codes are on the id plate inside the door?
I have VIN decal decoder but it's on disk,is there a part of it you need to know about?
1 Exterior Paint Code
2 Region Code
3 Domestic Special Order Code
4 Wheelbase Code
5 Brake Code
6 Interior Trim Code
7 Tape/Paint Pinstripe Code
8 Radio Code
9 Axle Code
10 Transmission Code
11 Spring Code
12 Powertrain Calibration Information
The top attachment is the white decal and the second down is the '02 Dash VIN Plate decoder.
scoutman77 said:
spring code = va
tansmission = 9
brake = 4
axle =c1
Front springs V codes,rear spring set A codes
Transmission Four-speed automatic overdrive (4R100)
Brakes should be Four-wheel anti-lock brakes system (ABS)
Axle C1 — 3.73 limited slip, F-250/Excursion
dboyw
Lancaster, PA
Again, here I go and post a link to the other site, but all of my good bookmarks are to there still.
This list gives VIN information, and information on the door decal.
VIN CODES
I just added this new VIN Decoder Wiki for the dash plate lemme know how ya'll like it.
It's data for the 01,02,03 models but I'll be adding content for the other years as necessary:sweet
