Injector Question
roosterdiesel
Earl needs B100
Amarillo,TX
I've made up my mind to go ahead and do my own injectors.:D Hopefully I'm not in over my head.
Now the question is, singles or splits? I can get some AA cores for about the same price of new barrels and plungers to convert my ADs.
Do you guys think 160cc singles would be better than 165cc splits?-popcorn -popcorn
:thanks
Hmmmmm, singles would be my choice but youll have to get a reprogam for the PCM no?
94f450sd
certified nutjob
plymouth,ma
yup you will need a different pcm program or chip program to run singles in a truck that had splits.but you can run splits in a singles truck i did for a while with no problems
roosterdiesel
Earl needs B100
Amarillo,TX
A new burn on my chip is the only thing really holding me back from the singles. It would be nice to get the AA's done and just have to install them. Instead of pulling, rebuilding, installing. Decisions decisions.:D
twildman
Ft Worth
Singles would definately be better than the splits, unless you go hybrid. Even then go with single shots.
roosterdiesel
Earl needs B100
Amarillo,TX
No hybrids with the PMR's.:(
I think I'm rolling the dice as it is.
So if I'm not going for the high number at a dyno day, should I still wait and get some singles to build? -popcorn
dserge66
