Injectors go bad for the third time!!!!
fordkerns
gloucester, va
I drive a 2002 f250 7.3 with Superchips, intake, exhaust, and boost fooler.
This is the third time i had to replace the 5th and 7th injectors and the second time i had to replace the value cover relay gaskets. If anyone has any info about why i has happen so many times that would be great thanks. I have also replaced the 1,3,and 7 injectors.
Ford
JRJ04
Houston, TX
are you positive the injectors are bad? Do you have any gauges to watch your boost and egt's? What setting do you have your chip on?
bbressler
Happy, TX
Is it possible that you had a bad harness, causing the injector problems? Maybe they were fried by bad glow plugs?
fordkerns
gloucester, va
it had bad glow plugs when i bought it so it could have done something
whatever i am about to ditch the split and get single shot injectors
dmd
Member
Double Oak, TX
What about fuel filter and air in the fuel? Sounds crazy that you should go through
so many injectors.
BDJack
chesapeake virginia
Have you been replacing them with new or rebuilt injectors? Ford will give you rebuilt ones unless you throw a fit. and pay extra:D
I have heard wonderful things about Industrial Injection. Talked to several distributors, and they said not one of them that they knew of had come back for any reason.
Sorry to revive old thread- just interested.
