Interior dome lights not working
bharney
Springfield, Illinois
Like it says. Interior dome lights not working.
Took my truck in for some of the recalls that it had not had done before.
Cost $190 for a leaking thermostat housing. Maybe should have taken the time to change it myself. Did not think it would be that much.
Need 2 new batteries. Only 450 CCA and should be 750 CCA. Will look into this. $125 each from Ford. Probably less from local battery store.
Still have the interior lights not working. The techs said they need to do more testing at a lot of cost, but think it may be the GEM module. I think I will do some more testing when I can and see if I can find a gEM module in a junkyard.
What do you think? GEM module and what is the more specific testing?
How do you know its the GEM module?
year, make & model, Bro..
also any mods..
put it in your signature..
did they say how they arrived a that conclusion?
bharney
Reply
1999 F250 Super Duty Supercab XL 4X2 with 7.3 Turbo Diesel and Automatic w/overdrive and no mods that I now of.
They said they thought that may be it, but not sure without more time and expensive testing.
sikodiesel
Andover nj
Sounds like a GEM to me! its an easy repair. just remove the radio and you can stick you meat claws back there
