intermitent battery light
Russ
Found On Russ' Drive
New Brighton PA
The other day the battery light flickered in the dash, then went out for about a week, tonight it flickered a few times. I noticed some corrosion on the battery terminals, could this be the cause? Batteries are 2 years old and the alt. is about 6 months old. Thanks
Zookie400
I WANNA GO FAST
wallingford, CT
it wouldnt hurt if you fixed the corrossion, but i dont htink thats your cause.
my alternator did the same thing with the batt light when it was on its way out, kinda "touch and go" before i took it off of life support and replaced it.
clem
N.E.Ohio
As Patrick said check the wires on top of the alt.Sometimes the heater hose rubs the coating off.
Russ
New Brighton PA
I checked the wires all seams good, didn't have time to clean batt. posts. Might be a bad rebuilt alt.
