Just died??
Dogman
tampa,FL
Coming into work this morning the truck just shut down. Tried to restart it nothing, had dash lights and power to the fuse box. But the started would do nothing. :dunno Had it towed to the dealer hoping the warrenty will cover it.
Dogman
tampa,FL
WELL!!! They said the EGT sensor is bad. So I'm shelling out 300 bucks to fix it. What gets me is why would that keep the truck from starting. It should have gone into limp mode?? Am I thinking right here??
I would think the same thing. :dunno
Me 3 ? Limp mode Yes ? :)watchout ? DEALER STUFF ? :watchout)
ducky1402
member
AZ
hard to trust the stealership :( hopefully that fixes it though
Dogman
tampa,FL
What I was told when I asked about the motor shutting down was that there is a message that comes up and says "Pull over safely and shut down motor." Well that never happened and that could be a very big problem if you were going down a hill with a load.
Here is the part number.Ford Part: SENSOR - EXHAUST GAS
Part NO.: 8C3Z-5J213-D
This was th fix for the flames coming out the tell pipe.
rhensonsr
