list of maintenence checks
97powerstroker
north port,fl
ive had my truck for around 6 months and i think i need some help with routine maint.ive checked oil,tranny,brake,clutch fluid,but im talkin other things like i just read about the fpr screens and then i went outside and checked it out and it was completely coverd in this sludge lookin gunk,im suprised it ran,so i cleaned it out,the fuel filter doesnt look to bad but it isnt white anymore,is there any other things like this,small screen or filters i should check?
Patrick Feeley
Tehachapi, CA
The only other thing (I'm not counting oil changes and stuff) would be to check the additive level in your coolant. The additive prevents cavitation that can lead to pin holes in the block cylinder walls. The level is checked using test strips that are available.
Coolant Test Strips
(Fleetguard) CC6202 (50)
(Fleetguard) CC2602A (four strips)
(Fleetguard) CC2602B (one strip)
Don't buy a pack of 50 since they do have about a year-long shelf life. Cheers!
97powerstroker
north port,fl
the antifreeze for these are the same as gas right? i can put in the regular 50/50 from the auto parts store.
dserge66
