The autumn is here and it's just the right time to get ready for the foggy mornings and long rainy days with the help of simple and effective solution - G10 LED Headlight Conversion Kit by Lumen. If you're looking to upgrade the light output of your truck, increase the visibility and safety, without spending a fortune, this kit is for you.
This conversion kit is a direct replacement for your standard bulbs and installs without any serious modifications. With an expected lifespan of 50,000 hours and a combined output of 4000 lumens, these bulbs will most likely be the last headlight bulbs your truck will ever need. Our tech expert Greg prepared a new, detailed video review on this product, check it out on our YouTube channel!
Lumen® - G10 LED Headlight Conversion Kit at CARiD
Specifications:
Light Intensity: 4000lm, per two bulbs
Color Temperature: 6500K
Power: 16 Watts
LEDs: Lattice Power
Beam angle: 360 degrees
Features:
Exceptionally bright light
Longer Lifespan
Cooler Operation
Easy Plug and Play Installation
Outstanding Quality
Backed by a 5-year warranty.
Get sufficient illumination for safe driving without any hassle with Lumen G10 LED Headlight Conversion Kit!
