Max tire size on my 2015 f250 sd crew cab
Fivelitreford
Nova Ohip
What is the maximum tire size I can put on my 2015 F250 without lifting and messing up the speedo??? Came factory with 275-70R18LT on it???
Thanks for the advice in advance.
As a rule....If you change the tire size, to anything other than the OEM tire size.. you will Need to have the speedo re-calibrated, either electronically, or mechanically... depending on year, make or model.
Ziefer92
Hinesville GA
I talked to a guy before with 2015 plow package that installed 35x12.5x20 Trail Grapplers on 20x9 XD 823 wheels with 18 offset, no rub issue.
