Miles to Empty
Johnswiftm
Matthews NC
I just helped a friend install a Transfer Flow 50 gal tank on his 2011 SD. Does anyone know how to get the miles to empty recal'd?
brianjbeach85
Va Beach/VA/USA
drive it till close to empty.. next time u refill should recal itself based on last number of miles exceeded?
Zmann ARGH
AZ
it's not possible IMHO and it won't fix itself .. the best I have figured is trying to get the long bed programming// the good news is it will read whaky but the last miles to empty will be close and won't let u run out of fuel ( very bad for a 6.0)
odalith
San Clemente CA
I discussed this with Transfer Flow, they told me the larger tank is incomparable with the miles to empty function.
Dogman
tampa,FL
WELL..... There not a fix. I have a long bed and the tank will hold a full 42 gal to the neck and that gets way off alot. SO until ford has a update that can adjust for the extra fuel your going to get a cell light or some thing like that. The only thing you can do is run the truck tank down to almost empty then transfer fuel till your full then shut off the other tank. The down side is the truck needs to be off untill transfer is done so the computer will rest. This problem is a software problem that ford has with the trip computers.
