Mud Flaps for 2011 Dually
gillesra
Delaware
I want to buy some mud flaps for my dually. I'm getting a lot of stone chips on the front of my new fifth wheel. What would be my best choice?
ducky1402
member
AZ
i had bought a set of diamond plate mud flaps that I liked real well.....
Dogman
tampa,FL
I had 35" on my other truck so flaps did not work, but I put alum. sheeting on my RV front to help with that problem. Dura flaps are the best I found so far on other trucks I have.
easyfour
Keswick Ontario
I have Dura flaps on mine. They are a great product, pull a 35 ft. 5er
with no problem. They are longer & sit about 6" from the ground.
(WELCOME to SDD.com easyfour ;tu)
Couldn't find any Mud-flaps I liked so I made a set, from Aluminum sheet. Painted Black. 19 1/2" wide, bottom 6" is hinged Aluminum diamond plate. Set about 6" off the ground with the 5r hooked up... "sail" when moving, or "swing' when crawling over stuff.
No dings, hits or pits on the "Hips" or the 5r. :dunno
tankerdude
Tulsa, Ok
Ford's "flaps" work good for me. The thing I like about them is that they fit right out of the box.
Hello Tankerdude and Welcome to SSD.com, like your truck.
Do you pull a fifthwheel or anything with your truck?
dserge66
