Question need a tune for sct sf3
rdaoust
hamilton ontario canada
ok i'm new with this programer i've set up my truck 05 f250 6.0 with the preformance tune but kept evrything els as normal.I need help on wich seting to use ,trany,gears,rpm i want this truck to fly
atk
Moderator
simcoe, ontario, canada
gears...set it too what ratio you have or leave at stock configuration
rpm...if you are talking about raising your redline, not a good idea, not on a stock motor in my opinion
trans...just have to try different settings till you are happy with it, i usually have firmer shifts and T/C lock in 123 when i run the preloaded tunes, which i am running now( did have custom tunes, long story)
now i am assuming the SCT you have is similar to the LIVEWIRE and does basically the same thing....if you want to get the most out of your SCT, GET CUSTOM TUNES....hope this helps
welcome to SDD....Hamilton is not to far from me
