Need help in Detroit
jflaig
Holland, NY
Hey,
My 2000 Ford F350 will not start. I have replaced the batteries, alternator and starter. Now the truck will crank, but will not fire and there is no smoke. The truck has the WTS light and there is rpm when cranking. I believe that since there is no smoke that fuel is not being injected into the cylinders. I was told that I need a good scanner in order to figure out what is wrong from here. Does anyone have the ability to scan my truck and help me out? I am located in Westland, MI. I can assist with fuel and what not, I really just need my truck fixed. Or can anyone recommend a shop around me where I can have my truck towed to? I need help quick! Thanks.
Any GOOD shop will be able to scan your truck and tell you the codes. Just be sure they can scan for CAN Codes and you should be good to go. Does the WTS light stay on for a moment or go off in a few seconds?
