Newbie need help
tex939
california
Hello and I NEED HELP ! 2001 f-250 sd 7.3 service engine soon light is on on dash. I was told this is the same as check engine light on our car, won't pass smog with light on. Thanks California. Was told I needed GPCM wiring harness. I Can have the code cleared light goes out for short time, then back on. Tried to zip tie both black and green plugs to GPCM body with no luck of light going out. Can you help me out? Thanks in advance.http://www.superdutydiesel.com/forums/images/smilies/icon_dizzy.gif
GPCM wiring harness ????
Something to do with the Glow Plugs ? Could you spell that out ??
OBTW... WELCOME to SDD.com. Glad you found us.. ;tu;tu
79jasper
El Paso, TX
Glow plug control module. Iirc, the cali emissions trucks got those instead of just a normal relay.
Sent from my *******-SM-G890A using Tapatalk
