new guage problem
1ofakindgt
akron ohio
Ok I got the trans temp and exhaust gas temp guages all hooked up and in. But where the heck does the supplied boost guage hose hook up. it says to cut into a stock vaccum line but I dont see any.
1ofakindgt
akron ohio
well i posted in the 94 to 97 so I assumed people would pick up on that lol sorry though. 1997 Ford f250 7.3
Patrick Feeley
Tehachapi, CA
Generally most folks will hook the boost line into the line that goes from the passenger side intake manifold to the MAP sensor located high on the firewall (passenger side as well). If you put information on your truck in your signature it will help folks out in answering questions. My answer assumes you have basically a stock truck with no intercooler added in (if you do have an intercooler, that would change my answer). Cheers!
with a stock truck Patrick has the right place to tap into for the boost reading... I'll admit I haven't relocated mine after adding the intercooler to mine:doh:
dserge66
