welcome !
share w/ us if you have ESOF (electronic shift on the fly) 4x4 or
the lever on the floor ?
ESOF:
the switch on the dash selects the transfer case (on or off) and the
gear range (high or low) to run the front drive-shaft.
the switch on the dash also runs a vac. pump that activates the
auto-lock hubs (when theyre set to the "auto" position on the front
wheel hubs).
if there is a problem locking the hubs by vacumm then you can get
out of the truck and turn the hub selection <knob> to LOCK...this will
lock the front wheels TO THE FRONT DRIVESHAFTS.
on the manual 4x4 (selecter in the floor) you must ALWAYS get out
of the truck to lock the wheels (that is to say there are no auto hubs
when you have a manual transfer case selection in the floor).
typical symptoms (or ways to know that youre in 4x4) is that turning
will be somewhat diffecult, on dry pavement (which no one would recommend)
tells more about your truck, auto/manual tranny, ESOF ?
itll sound strange but is your a/c heat vent working ok ? (if there is a vac. seal
leak @ the 4x4 hubs the system will default to defrost)
