New product release at CARiD.com: Aries & Dee Zee Running Boards for Ford F-Series
If the relentless pursuit of outstanding performance has inspired you to add a set of larger wheels and tires on your ultimate off-roader and equip it with the lift kit, make sure to take care of your convenience by installing a set of side steps. Dee Zee and Aries have recently released new custom fit running board sets, designed to make the entrance and descending process from your truck's cab a little bit less challenging for you and your family. Depending on your needs, preferences and driving style, choose running boards set which is the most suitable for you, see the key benefits of each application below.
The next generation of power-operated ARIES ActionTrac running boards are equipped with smart sensors and feature innovative Step-within-a-Step design to provide you with an additional leg up. They extend from 8" and up to 15" below when the door opens. The step surface is lighted to make it easy for you to use them in the dark. The installation process is easy, no drilling is required. Proudly manufactured in the USA from durable and non-corrosive powder-coated 6061-T6 aluminum, they are guaranteed for years of great rust-free looks and smooth operation.
Aries® - ActionTrac™ Retractable Black Running Boards at CARiD.com
aries-actiontrac-retractable-black-running-boards-on-truck-installed-5-with-snow-close-look-forums-600.jpg
aries-actiontrac-retractable-black-running-boards-on-truck-installed-5-with-snow-forums-600.jpg
Notes:
* 1 Pair;
* Material: Aluminum;
* Length: 79" / 83";
* Equipped with smart sensors for safe, automated operation;
* Power step drops 8" when door opens, up to 15" below the door sill;
* Made from durable and non-corrosive powder-coated 6061-T6 aluminum;
* Mounting brackets Included;
* Rated for 650 lbs. static weight capacity;
If you are on the market for tried and tested application, classic wide running boards developed by Dee Zee will definitely make the appearance of your truck more rugged and aggressive. Manufactured from heavy-duty steel, and coated with the NRT texture black powder coat finish, they are so far one of the most suitable applications for your truck. Being absolutely maintenance-free, they will provide you with the extreme strength and sure footing for years.
Dee Zee® - 6.5" Louvered Black Side Steps at CARiD.com
Notes:
* Made of heavy-duty steel with a textured black powder coat finish;
* Custom-fit bracket kit for most applications (Sold Separately);
* No drill installation with custom-fit brackets (Sold Separately);
* Looks great with Louvered Sport Bar;
Enhance the functionality and appearance of your truck with running board sets developed by Aries and Dee Zee, see more options available for your Ford F-Series at CARiD.
