New Rotors
YODA
Colorado
Need new front rotors. Stock ones warped again, and I do not think there is enough left on them to turn. Any thought on something other than OEM Ford?
Thanks much:)
Thanks much:)
I have white-box specials on mine.
police stroker
Dallas, Texas
Make sure you check the grease pins that the calipers ride on. I think this is what lead to mine warping?!? One pin was stuck causing a bind on the rotor/caliper due to it not floating and moving with the pad wear.
Just a little FYI I ended up turning my rotors, new pads, new caliper mounts(due to pins being seized inside), and fresh loaded calipers. Thank god my brother works at ford got me the brother discount :sweet :D :sweet
irish4x4
Mayor of Margaritaville
Reno, Nevada
Aslong as your replacing things, you may as well upgrade. Hawk LT pads and drilled and slotted rotors here.:2c
