new superduty options for builds after july 30th 2007
they're using the crap TPMS sensors...
most everyone else is using the valve stem mounted ones
:soap TPMS is a federal mandate for 2008 & beyond
Goodyear & every other majore tire manufacturer are against it; the systems aren't sensitive enough, and only monitor air pressure; not air pressure, temperature and load conditions.
What it's gonna result in is, lawsuits saying "Well, your tire failed, and the TPMS never made warning"
When in reality, if the tire was overloaded, and failed, a'la Ford Exploder, the temperature is the more pertinent condition...
:rant mode off.
damm a limited slip 3.55 rear option !
Electronic Traction Control
200 amp alternator <when you get the rapid heat> !
PATS key avail on ALL trim levels.
and a nice 19gal optional 2nd tank !
Dual zone climate control & looks like the mirror heat is on
a switch now...
Looks like they did away w/ the trans by-pass filter (not sure i like that) !
TorqShift® transmission external oil filter is
replaced by a High Efficiency Sump Filter
(HESF) located inside the transmission bottom
pan. The new filter doubles the miles between
replacement intervals (60,000 miles versus
30,000 miles) to reduce service costs. (Late
Availability.
circle1110
utah
Hi, New to this site. Have a problem with the tpms. How can we get rid of it
dserge66
