JMF350
Here goes.... I've got a '91 F SuperDuty with a 7.3. On cooler mornings (50-60 degrees), when I go to start it, sometimes it will hit, but not start. I can do a quick either shot, it'll hit, start for a half second, die. Now the messed up part.... if I go to restart it, it will crank over like a gasser with all the plugs out (but without the swoosh sound). Let it sit for 5-10 minutes, it has compression again. Do it all over again. Again, if it hits, but doen't start, it cranks over with no compression. If I plug it in over-night, it will start OK, but if I don't let it idle for 5-10 minutes, try to give it any fuel at all, it developes a miss and may die. If it dies.... you guessed it, no comp. Another thing, if I let it get heat in it, 10 mins. or so.... it runs and pulls STRONG!!! Runs great. Also, on the no compression cranking.... if I get mad and just crank it like this for a while (30-60 seconds), it will blow the oil filter off (well, the o-ring anyway). Any ideas
