no start
chuck416ex
warrenton,oregon
last nite turned truck off went. to start about 10 min later and would not turn over or start,can jump the solenoid with screwdrivers and truck runs fine.just put new solenoid on,same thing.checked all fuses with test lite and they test fine.any ideas?
Tbar
SDD STAFF/Moderator
Get some one to help you. While they turn the key put a multimeter or test light on the starter side terminal of the solenoid.
If no voltage on the above terminal put the test meter on the low voltage terminal of the solenoid. If you have voltage here think another bad solenoid. If you do not have voltage look in the ignition switch circuit.
Tbar
chuck416ex
warrenton,oregon
thanks for the info, i called a buddy over and took his solenoid and truck started,swaped the new one back on and still no start.guess i'll call the parts store in the morning for another solenoid.
