Offset for 2001 F350 dual wheel
afinepoint
Virginia
I've looked it up and the offset is supposedly ~ 134 - 137 from two sources.
I have new wheels that are 115. The tires are 235/85R16.
Has anyone experience with a smaller offset on a stock truck? Will it work without rubbing together on the rear or on the body/suspension on the front?
Thank you.
Sorry. Digging further the rear wheels I ordered are 137. The picture on the site showed a wheel representing all four with a spec of 115. Only the front are +115.
I'm still researching the front offset. Two sources are showing ~136 same as the rear. I've yet to find one stating 115.
However doing more research the front and outer rear do not have the same offset. The rear are highly negative to prevent tire to tire contact. The front highly positive to clear the fender. Thus front and rear (outer) aluminum wheels can not be swapped. Steel wheels can be swapped with each other. A truck with six steel wheels can do a six wheel rotation without the costly dismounting of the tires that aluminum wheels require.
I'm thinking I have the correct wheels.
TEly
Back
