Oil pan issues..
someone refresh my memory..
There is a way to replace the oil pan on a 7.3 without putting the engine..
but I canna'e remember it..
Yes you can John. You can jack the engine up as high (loosen the engine mounts) as you can get it and it will come out.
Dave ;tu
have to unbolt the oil pump pickup.
that's the part I was missing..
it's Pantazis' truck..
he sandblasted it then coated it with some epoxy stuff, and hooked a shop vac to the oil filler to pull negative pressure while it cured..
I haven't talked to him in about a week, so I can't tell you how it turned out..
02Oilburner
SDD Power Hungry
Raleigh, NC
I was wondering if I could change the oil pan gasket also! Mine is marking her territory a little to much lately. Any write up on this?
Tbar
SDD STAFF/Moderator
That's wild....... :wow
94f450sd
certified nutjob
plymouth,ma
There is no gasket.its sealed with high pressure grey rtv.there is an aftermarket gasket made by moroso for them now but its a hundred bux.are you sure its not the dipstick adapter,rear main or something up top?
For rusted pans there is a thing called a diaper for it.its a fiberglass shell that you glue to the pan.ive heard that it works very well when done right but i wouldnt trust it.the rusting/rotting steel is still gonna rustand the only place for the chunks,dust and crap have to go is inside the pan to be sucked up by the oil pump.
Ive got a 97 here to put a pan on.my only option is to pull the motor.if you can weld,you can cut the center of the crossmember out,swap the pan and weld the piece back in.i wont opt for cutting the crossmember since im getting 800.00 for the job
02Oilburner
SDD Power Hungry
Raleigh, NC
I checked and she is leaking diesel from the drain valve. I will also check the dipstick adapter just to see if it needs any attention. Thanks 94f450sd!
idismoke
