Ok lets make sure I got everything for upgrades.
Scar13
Little elm, tx
1. Wicked wheel, whats a good price for this?
2. CCV what exactly do I need besides some hose?
3. Shim, do I need anything spacers I take it?
4. Transmission ? Bully Dog Shift Kit ?? somethign better maybe ?
5 ?
Anythign else you gents can think of ? As soon as the MTN bike sales Ill get the gauges, exhaust and chip.
at 30 and Married money is like Sex I knew I used to get it, but cant remember exactly what it was like...
Wood County Tx
I am not a big fan of shimming the regulator,
I prefer to block off teh factory regulator, add an aeromotive one and route two return hose from each head to a regulator then return this un-used fuel back to the tank. it sure quietened my 7.3 and all but cured the idle knock
but shimming is easy and its low dollar to bump up the pressure of the fuel entering the heads.
the reg with hoses will run you about 200 smackers.
whatabudro
Launched
5 ?
1. about $60
2. 3/4 ID hose by 7', 3/4 by 3/4 hose barb coupling, 4"OD pipe 3.5" long
3. We can probably handle supplying the washers for ya
4. Sonnax/Tric kit $50 shipped from blackclouddiesel.com plus a new tranny filter and 5-7 quarts of fluid.
We can do most or all of these at our next mod party.
Scar13
Little elm, tx
Dumb Question.. What is the 4"OD pipe 3.5" long for ?
I thought we flipped the CCV toward the firewall and ran the hose out the back?
whatabudro
Launched
Where the CCV is connected to the inlet side of the turbo. There is an obstruction inside this piece that once removed increases airflow to the turbo.
If you just disconnected the ccv and left the peice in tact than you would have a 3/4id hole in your inlet tube that would be sucking unfiltered air into your motor.
Tbar
SDD STAFF/Moderator
A few pics..............
http://community.webshots.com/album/323742027nDYbEI
Tbar
BBBxcursion
IL
You can get the Wicked Wheel and shift kit from Garret at blackclouddiesel.com I am also not a fan of shimming the regulator. Dennis at ITP has a GREAT regulated return kit out.
Scar13
Little elm, tx
Tbar,
Thanks! I was thinking it went over the other piece, nope I over analyzed its just a replacment! Perfect sense!
Now abou that regulated return Kit ill look that up!
jvencius
In a van down by the river...
BBBxcursion said:
I think it's itpdiesel.com Dennis is great to work with.
Yep, here's the ITP LINK . I can't say enough about Dennis--I've bought quite a bit of stiff from him in the past and he's a stand-up guy to deal with.
Bob Riley @ DIESELSITE is another good fellow to deal with--he's also got a bunch of my business in the past and he's never led me wrong. He sells fuel system kits too.
CarmaO282
