Oregon version of cold air intake
seawolf
HA(L)-3 DET-9 69-70
Oregon
Grill mods
I assume you noticed that I did enlarge the plastic grill openings laterally. Behind there, welllll it's functional but not so pretty. I removed the driver side solid radiator support and replaced it with upper and lower supports. I made these with angle steel and a piece of 3/4 x 1 1/2" steel tube. Solid as a rock amd that left enough vertical space. I then trimmed and finessed horizontal space with a jig saw, hammer and vice grips. Learned that from orthopedic surgeons. A bigger hammer is always better. The two ram air hoses are 3" plastic drain pipe.
HOOKUM HORNS
dserge66
