Other parts and repairs
dboyw
Lancaster, PA
With the pending trans replacement, what other issues should I look at? My list at this time consist of:
Rear Main Seal
A Gasket for between the trans and transfer case
Drive Shaft U-Joints
Anything else?
Any recommendation on the parts? I swear I have been looking but I am not finding the info about the parts. I guess I'm too fried due to all the research and reading I have been doing for the trans.
Thank again for the help.
RSG
Savoy IL
All the bushings you can get to in the front end. Really tightened up things: here's where I bought mine, here's what I bought:
Part Number: 4.5186
Product Name: Complete Front Sway Bar and End Link Bushings Set - 32MM
Quantity: 1
Unit Price: $37.06
Color : Black
I'm guessing you're planning on doing the repairs yourself. I'd recommend going ahead and replacing the rubber transmission mount, and the hanger bearing in your driveshaft while you're replacing the U-joints.
dboyw
Lancaster, PA
Would this be the correct carrier bearing? The first one HB88107A 35mm?
For a crew cab, short bed truck. I know it has the slip yoke in the rear drive shaft, I've greased it before.
Thasks
