Overheating
Alaska Tower
Ok here goes
I have a 2000 F550 6speed 4.88 rear
19.5 rollback unit
Had it just over a year, 95000 miles, On local runs it does just fine 20 miles or less, on long hauls running with a load or not, temp spikes while climbing hills.
Last night I had a 2005 neon on the back for a 300 mile tow, while climbing hills temp at the upper most normal level, has got into the red once never lost any fuid.
The Fan clutch has been changed, stat has been changed, rad cleaned, to no avail.
Running out of ideas..
oi8228oi
another 99
is it 7.3 i assume....
thermostats sounds like it must be working.... fanclutch works..... rad cleaned....
you still on your original water pump? maybe theres a higher flowing water pump out there? maybe a coolant addative might help out a little bit if that hasnt been tried....also change to the fluids that advertise 30* cooler.... just some suggestions
also welcome to the crew.....
give us a signature and tell us all about your rig (year, mods, ect).... it helps us to help you
If the radiator has been cleaned, did it get painted with acrylic enamel?
Other than that, I'd look at things like condensor fins damaged, etc... and yeah, I'd probably pull the water pump and check the impeller...
