p 1212 no start
kyhillbilly
03 7.3 no start
A buddy of mine has an '02 7.3 F350 he runs an excavating business and uses his truck every day to earn a living.
He can spray starting fluid in the intake and get it to start and it will run all day long (as long as you don't turn the key off)
But it will not start without a shot of starting fluid any ideas?
Kevin
kyhillbilly
He is getting a P 1212 code.
The truck will not start without a shot of starting fluid any ideas before he starts replacing expensive parts?
Thanks
KYHillbilly
Tail_Gunner
CRJ & ERJ A&P Mech.
Da U.P.
P1212 is: Injector Control Pressure Lower Than Desired (engine crank or run),
so says Autoenginuity.
Tbar
SDD STAFF/Moderator
Hummmm..................Starter Fluid and Glow Plugs. :confused:
Tbar
Tx_Atty
Master Baiter
Fishin'
tell him to quit the starter fluid before he really damages something.
our wiki says:
P1212 ICP Voltage Not at Expected Level
kyhillbilly
Thank you the message has been sent.
Thanks twildman!!!
kyhillbilly
action4478
Muskegon Mi
DC14 CONTINUOUS DIAGNOSTIC TROUBLE CODE (DTC) P1212
Note: This code may set after a high-pressure oil system repair (i.e., injector change). Drive vehicle to clear air from system after repair, and clear code.
Continuous DTC P1212 indicates that there was no ICP detected during crank (long crank time).
Possible causes:
empty/low oil reservoir at crank
low engine oil level or incorrect viscosity
IPR circuit fault
damaged low-pressure oil pump
damaged IPR valve
damaged ICP sensor
damaged high-pressure oil pump
Check engine oil level.
Perform KOEO On-Demand Self Test to verify ICP/IPR circuit faults are not present at this time.
