Partially hydrogenated oil... yes, no, maybe?
sagebel
Stock? Pfft!
Albuquerque, NM
I can't seem to remember if partially hydrogenated oil is useable to make bio-diesel. If I remember correctlly, you can use it but it will cloud sooner. Someone let me know if I am right or wrong, thanks.
Scott
girl Mark
California
Yep, it works fine. Now the problem with it is that any soap you make out of it is likely to be visible and solid. There's an annoying 'catastrophe' that can happen called 'glop'- there's an example in the middle of this web page:
http://localb100.com/cbt/testingoilforwater/
anyway, glop can happen sooner if you're using both NaOH (lye- rather than KOH, which won't cause glop) and either animal fats, hydrogenated, or tropical fats (palm, coconut oils etc). It's preventable if you do titration and don't use oil over 3 or 5 with NaOH, or use KOH for any of your fuel (buy KOH at www.braintan.com)
and yes, any of those fats will also make a biodiesel with worse cold flow, so you'll gel at a warmer temperature than you would if your fuel was liquid canola for example.
Mark
sagebel
Stock? Pfft!
Albuquerque, NM
My initial sample titration was less than 1. I did a 4X titration and ended up with .5. Is it better to use KOH rather than NaOH? I just checked out the link, they sell pork brains! I may go with the KOH due to not being able to find a bulk lye vendor near by.
Scott
girl Mark
California
Sounds like great oil to me!
KOH is easier to handle- the glycerine is always liquid rather than a gel (with such a tiny number on titration your oil will probably have liquid glycerine anyway even with NaOH). It's also much easier to dissolve into methanol than NaOH is.
Mark
