Pistons??
lukecline
Kansas
not really a definitave answer to that, you shouldnt have to worry about breaking them unless you have a weak one or somehting like that.
lukecline
Kansas
If your gonna be making enough power to push 50+ psi boost, your gonna need an engine build IMO.
In your 02, stock rods/stock heads, you are pushing your luck at 35+ psi boost and or 400 HP. If you are serious about 50+ psi boost (boost doesnt = HP btw) then you are going to need what Luke suggested and that is an entire build from the crank up. Head studs (maybe head o-rings too), forged rods, fuel system, high pressure oil system, turbo upgrade, injector upgrade, and PCM reprogramming. Dont forget that your going to have to build up the drive train to get it all to the ground too.
But it sounds intersting, keep us informed on what you got going on. Theres a couple of the guys here dabbling in high HP PSD's right now. So, there is some good knowledge here.
scotty7751
Big Daddy
NORTH Dallas, Tx
well im getting a truck right 99-02 now so i can mess around with the programmable chip in the ecm then its motor yankin time its gonna be ground up motor hopign for BIG HP.
