Popping through intake?
94f450sd
certified nutjob
plymouth,ma
Is it the usual culprit, bent/burnt/sticky valve or is there something weird with the engines causing it?
Hey.. Good to hear from you Rich ;tu
Sounds like the usual, but is the Coolant & Oil clean ??
Tbar
SDD STAFF/Moderator
Dang Roy.......could that sig picture be any bigger? :) :) :)
Tbar
4x4grey88
Nascar Fan #88
Kalifornia
I just had the same thing and mine turned out to be a bad cam lifter. The needle bearings on the bottle of the lifter let loose and now the engine will not run at all. some of the needle bearings made there way into the oil pump gears and stopped the oil pump - thus - no oil pressure - no oil pressure to the high pressure oil pump - thus - engine will not run.
My mechanic now tells me that I will need a total re-build to remove all the needle bearings
If your intake is making a puffing sound have it checked out right away.....
I am thinking that I should just drop another 6.0L into the truck, as I can get one for about $2200.00 and total re-build will run over $5000.00
It might be time for me to dump my lemon.
alex3012red
San Diego Ca.
I have turbo farts on mine and power is not the same, even after new injectors, how can I or the mechanic see if that is my problem, my turbo was cleaned at the valves they were not bad, so im thinking I could have this problem.
Scan your truck and see what codes come up. That is the only real way to diagnose the problem.
Dave :)
