Power Door Lock Problem...
FINKSTR
Pinckney. Michigan
OK, fellow SDD enthusiasts... here's an SD question for you. I have a '99 F350XLT Crew Cab with the standard power door locks. For some weird reason none of the door mechanisms will cycle either full up or full down when either door button is pushed. It's like the system isn't getting enough juice or has a bad ground. I've checked the voltage: OK. Checked the ground too: OK. I even removed the mechanism from the driver's door so I could watch it cycle thinking I might get a clue. Nope. What's even more strange is that the more times I push the button(s) either up or down, the slower it gets to the point where it will hardly move at all! I'm going nuts trying to figure it out. Any suggestions??? I dunno...
