pro comp 35/12.50-20's on an 08 no lift!!!
z71burb
08 owner
tucson, az
got a set of pro comp xtreme a/t's mounted yesterday. 35/12.50-20's on the stock 20" wheels, no lift.
my f-250 sits almost level ('bout an inch higher out back) and these had plenty of room. i do have the fx4 package with the stabilizer package as well, which has stiffer front springs and the front swaybar, so i dont know if that affects the height of the front at all.
also, the tires are a good inch away from the radius arms at full lock. i tried to hit the bump going into my driveway with the wheels at full lock and never heard any kind of rubbing whatsoever.
anyhow - on with the pics!!
Looks good, but I honestly think you need another 2 to 3 inches of lift to make it look just right.
Those bigger shoes fill in the wheel wells too much. It actually makes the truck look lower over the tires.
fordtrucker4life!
I work with waste
SE Michigan
Yeah alittle lift would look better, but I kind of like the stocky look. Just my personal preference.
Romie64
