Quick gauge wiring question..
chasespeed
Corpus Christi, TX
Got my pillar mounted today, ran outta time, and had to go pick my daughter up..
Where am I supposed to tap into for the lights???
Chase
Tbar
SDD STAFF/Moderator
I removed the headlight switch panel and tapped the wire that dims the factory dash lights.
If you have never removed the switch panel......don't force it......it literally has a combination to it.
Tbar
Tbar
SDD STAFF/Moderator
Someone will correct me if I am wrong...........
1) Turn headlight switch to on
2) Pull out on the knob
3) Insert paper clip or something similar into the small hole on the back side of the knob to release it.
4) Remove knob
5) Rotate 180 degrees and push back onto stem
6) Turn headlights off
7) Push in on knob and rotate back to on position(clock wise)
8) Gently pull out on the knob and the whole plate should come with it
Tbar
chasespeed
Corpus Christi, TX
Thanks gents...
But, I stuck a small precision screwdriver in between the panel, and the dash, and pop.. out it came...
Found the right wire, and viola...
I come inside to read all these posts....
Its cool though...
I really need to snag a service manual for this thing...
Chase
