Quick Wiring Question
Bigboytoys
Manitoba, Canada
I'm installing air bags on my truck and going to mount a pressure gauge in the cab around the left side of the cup holders. I need to tap into the dimmer side of the dash lights, where's the easiest place? All so where is the easiest place to tap into the reverse lights in side the cab? What color is the wire?
Bigboytoys
Manitoba, Canada
Ok I've installed the compressor and valve and the gauge into the dash lights, that went fine but still can't trace down the reverse wire without splitting open that nice small harness at the fire wall. Where is the reverse switch within the cab? Next easy question is, has anyone played around with the driving light wiring? I'm thinking of making them stay on when the high beams are on also?
Bigboytoys
Manitoba, Canada
After a trip to gouge city, ah mean the dealer ship, the reverse wiring doesn't run in the cab, switch is on the trany, but there happens to be a conector right around where the harness comes out of the cab on the frame btw.
So second part, no one has played around with thier driving lights or what?
