Question Radio timer (15 minutes)
IHC Power
STOCK STROKE
Walpole Mass
Hey all you guys with 2003 and newer superduties i need to know where your radio switched 12 volt source is that leaves it on after the ignition is shut off. I am going to wire through the power window relay but would be interested in how the new body styles are, any help is good and opinions.
Zmann ARGH
AZ
so that is the retained power wire? I have been looking for it also ,, when I turn my truck off my xm radio shuts off and I am stuck listening to mexican radio lol
IHC Power
STOCK STROKE
Walpole Mass
Update
Hey all just wanted to let you guys with a 2001 and older if you have power windows after you shut the truck down you can get your radio with it also, i poked around with my meter and found relay #5 in the passenger compartment controls that function, if my memory is corrrect it should be terminal 86 that you can jump and run to your radio.
