Rear Diff Temperatures?!?
6LMonster
Wake Forest, NC
Does anyone know what temperature the rear diff's run at? I used an infrared thermometer on mine this weekend and here are the temps I saw:
Empty: 144*F
Towing 5,000 lbs for an hour: 172*F
I am asking because I am trying to decide if I want to go to the '08 finned rear diff cover.
Thanks
HighwayPrisoner
The RV unemployment Capital
The info passed on to me awhile back was: 195 ideal, 220 ok when towing, 250 too hot, stop to cool down. I have a Mag-Hytec rear cover on my Dana 80, and usually see around 180 to 220 towing in warm weather. I have seen a little over 220 degrees towing heavy in hot weather. the finned cover might help a little, but for regular towing in hot weather the Mag-Hytec seems to help.
96P_Stroke4x4
philadelphia, pa
why not go for the 08 cover anyway? it can be found for around $30 or $40 and it looks much better than the stock cover.
96P_Stroke4x4
philadelphia, pa
i don't think it will fit the f-superduty axles, but it will fit the sterling 10.25. powerstrokeshop.com has them. you also need longer bolts because the alum cover is thicker
Tx_Atty
Master Baiter
Fishin'
crumm, I hate to ask, what exactly are you doing polishing the aluminum cover? Am I going to need to make some mod of a new cover I have already put on to meet the standard you are setting?
