Reflectix
Maxtor
Redding
How many of you use this insulation on your RV's and how do you like it?
People from one of the 5th wheel websites, say they use it on their cargo doors and windows.
looks like the double-bubble that my 'zact fit window shades are
made from.
Friend of mine insulated his entire building/shop in it...it performs
fairly well (for window shades).
might be able to find it cheaper....i know i get some industrial/shop
supply mag. and its always in the catalog...in large rolls.
double bubble insulation - Google Search
Wood County Tx
max
i use the doulbe bubble foil backed windshiled protectors under the dinette bench seats it does help some.
but the best was the 1" thick poly urethane foam boards , cut em to size and attatch with adhesive or screws and use GOOD foil ducting tape to seal teh edges. i did this with the subfloor over the basement and it really cut the chill factor in the bedroom
and you would be surprised how much air stoppage you can get just by a using a can of expanding foam and get al lthem wire chases and plumbing holes sealed up.
i bet that foam "boards" go a long way in making things
a bit quieter (walking on the floor) too !
Ive used the "blue" (non-foil backed) foam board insulation on
my (non-insulated) garage doors...makes the door operation nice
and quiet and it really blocks the <texas> HEAT.
