Help Needed Remote entry system
cicguy
Sierra Vista, Az
My system is not operative. I put a new battery in the transmitter. No luck. I then tried programming it as per the owner manual. No luck. The owner manual is no help as to which fuse may be worth checking. Anyone know which fuse to check, also any advice what to do next? Thank you.
dpantazis
#12
under the cheddar curtain
ummm, you mean you tried the owner's manual that is specific to the YEAR and MODEL of your truck? that might help if we knew what your truck was...
what, if anything else is not working right now?
what did you do LAST to your truck?
cicguy
Sierra Vista, Az
I have a 2002 F-250 7.3 diesel 4x4 and I used the 2002 issued owners manual. This is a sole and separate issue that happened sometime ago. I am now trying to solve it. Thank you
