Question Removing power sliding window
wargle
Talladega, Al
I have a 2010 F250 crew cab. I recently broke the driver side panel of my power rear sliding window. Does anyone have information on how to remove and replace the window?
First off Welcome to SDD.com, glad to have you here, I know nothing about them, I would have to take it to a glass shop to have it repaired.
What Doug said.
I looked at mine (012) to see what could be done.. looks like a job for the Pro's to me too. Lot's of sealant to remove and replace... unless you know what yer doing.
Neura
Rear windows are press fit. Get some non marring bars and you can pop the whole back glass out with the seal. To install once glass is replaced you need 2 guys and a rope and you are going to pull the window and seal back into the hole with the rope.. and just work your way around... takes an hr or two to do..
