TLDR; Retrofit Bestop Power Boards with Amp Research parts for ~$400 shipped.
My Bestop Power Boards [part# 75134-15] on a 2011 Super Duty had the motors burn up. The replacement [part# 489.39] is out-of-stock everywhere online. When I asked Bestop, they say it's been replaced by [part# 491.2P] and are available for ~$250ea. But, they're end-of-life, as Bestop has exited the running boards sector.
Luckily, Bestop pretty much made a knock-off of the Amp Research Power Step [part# 75104-01A] and [part# 75134-01a], which are still supported! The Amp 'motor linkage assembly' [part# 10-02624-14] is a retrofit replacement for the Bestop. I bought a replacement pair from Jegs for ~$150ea.
An Amp 'motor' [part# 19-03129-11] will also need to be purchased, as the Bestop motor is not compatible. The Amp motor is better known as [part# A10049-113] and [part# 80-03129-90] and available thru Amp for ~$70ea. Or, off-brand motors are available for ~$40ea.
Lastly, new plugs for the Amp motor connectors are needed. They are Delphi Metri-Pack 280 available for ~$15.
Now, with the long-term availability of Amp Research parts, if my motors burn out again, I can get readily available replacements!
