Scaled the beast....
s d mills
Close to the real OC 47462
Weights as seen in the first photo; me, full tank (38 gallons), two loaded suitcases, and 850-lbs of tools, maintenance items, and recovery gear in the bedbox.
Truck ratings:
GVWR: 11,500
Frt GAWR: 5,200
Rr GAWR: 8,250
5-er GCWR: 20,000
Max Trailer Wt: 12,700
Was previously concerned about weights with the 31' 5-er in tow. Trailer dry weight is 11,480 with 2,280 kingpin weight. Even if I didn't have to remove the sleeper and bedbox it appears I'll be good to go. Happiness has been my constant companion lately.:D
Wood County Tx
i find that amazing how you scaled exactly 8500 lbs
that is an easy number to add with :D i should be so lucky
good looking truck with the sleep box:sweet
I am scared to weigh mine....
whatabudro
Launched
Yep I weighed my nova a few months back on a cert. cat scale and it was an even number also.:dunno
