Silverstar headlights
85buggy
Medina OH
I've always replaced the headlight bulbs with Silverstar by Sylvania they are a heck of lot brighter than stock bulbs. I've been kinda lost because they weren't available for my 06 350 with the H13 or 9008 bulb. They were just put on the market this week, I picked up a set at Autozone the only set they had. But I'm just posting this for others that need this size and to let you know it's now available on a limited basis.
whatabudro
Launched
You should also replace the factory fog light lamps with 9005 silverstars if you have them.;)
85buggy
Medina OH
I did those too
I picked those up too $19 x 4 that all added up fast!!
dante59
greenbrier, AR.
hi ya ! i was wondering if anyone has the #'s for silverstar bulbs for my 96 f-250?? iv'e never had the bulb's out but i have read along the line it can be a little dicey getting them in-out. what do you think ?? best regards to ya all. dante59.( rich)
Tx_Atty
Master Baiter
Fishin'
unless there was some change between 96 and 97, they are very easy to remove/replace. You simply disconnect the wires and twist the plastic base cover to remove the tension held bulb assembly. I noticed when I did mine they are apparently pressurized somehow as they both gave a loud "whoosh" sound when they broke free. They go back in just as easily. Do NOT touch the glass with bare fingers. Skin oil will create hotspots on them and cause them to fail more quickly.
I didnt do the harness upgrade (yet) and Im not sure I can tell much, if any, brightness difference. The light is whiter but that is all I can notice.
I found a two pack on ebay for $20.
Digital Oxygen
Got Boost?
Rockies
So the Silver star 9005's are brighter than the Silverstar Foglights replacements? I can't remember the number now. :(
Tx_Atty
Master Baiter
Fishin'
BK - can you modify the lights to keep dims on with brights without the upgraded harness? I suspect you could since that happens with the flash to pass.
dante59
greenbrier, AR.
HEY! thanks for the great input , i had no idea about the harness, just shows to go ya, ck in 1st !! before i turn in to clark w griswall. aka sparky! thanks ya all.. rich..
