Small Diesel? Air Sled
danegreen
Northern New York
I picked up a small hobby lathe and mill a while back and needed to break them in. This is a project I put together from some leftover RC stuff. No spark plugs so I guess that makes it a diesel. It has 0.4cc engine and is way over powered. It would jump up to about 40mph in a hurry. It flew, almost literally. I had trouble getting it out of a turn. More R&D on the control surfaces.
Zookie400
I WANNA GO FAST
wallingford, CT
AWESOME!!!
what mill/lathe do you have? i am looking into getting one but i dont know which to get, nobody around here has any feedback with any of them.
id like the hear more about the lathe too.
what parts on that did you mill ?
maybe you could flip those mean lookin teeth
so that you would get more down force instead of lift.
danegreen
Northern New York
mini-lathe
I forgot to mention that this was designed to run in the snow. The teeth are patterned after one of my favorite WWII fighters, the P40 Warhawk.
I picked up my mini-lathe and mini-mill through Homier. They have a travelling tent sale that goes through here once a year or so. They also have a website. Most of the "mini" series machines that are available are manufactured by the same company, in China, but sold through various outlets; Homier, Grizzly, Micro Mark. I went with Homier because they were about $100 cheaper for each than anyone else. The machines are "assembled" when you get them. You need to break down the major components, clean, re-assemble, then adjust gibs etc... to get the most out of them. you can easily hold 0.001"-0.002" with these machines. Some have even been retrofitted with CNC.
The parts that I milled for the sled were the Lexan base, front end, and motor mounts. There is a "velocity stack" that I turned from some aluminum stock. Ive also done bushings for the bogie wheels on my brother's dryer, bore holes larger than 1/2", shear pins for the snowblower, and other stuff like that.
Here are some links for the mini series machine tools.
mini-lathe.com home page
Homier Distributing Company, Inc.
LittleMachineShop.com - tooling, parts, and accessories for bench top machinists
Micro-Mark: The Small Tool Specialists | Photo Gallery
Model Engineering
F350DRW1
Waylon Fan
N.J.
What fuel / oil mixture you running in that? Something already brewed or a "special" mix?
COOL ! :clap:
rhensonsr
